My question is about the difference between pwm and variable voltage control:
We all know that to control the speed of a DC motor,pulse width modulation is the common technique where a switching circuit connected to the motor,
switch the power from on to off repeatedly respecting a specific duty cycle:
Duty cycle=("on time"/periode)*100
The motor will operate on the resulted average voltage which reflect on its speed.
I was wonderig why not simply connect the motor in series with a rheostat to the power supply and varies the resistance to change the speed(law of addition of voltage)
I read on Wikipedia that this was the traditional way before introducing pwm,but it had some disadvantages related to the power dissipation and others things,anyway Wikipedia did not explain much.
Maybe you can give me a link about the subject
thank you
thank you
