hi everyone...need some advice that will probably be pretty simple to answer, but Im new at all of this stuff.
What I am looking to do is build a manual torque converter lockup switch for the transmission in my truck. Its PWM, so I cant just ground the solenoid control wire and get lockup.
Its pulsed at 100hz and the solenoid draws about 10 amps @ 12vdc. It constantly gets 12vdc and then the TCM (transmission control module) has a control/ground wire that it pulses on to lock up the torque converter. 0% duty cycle is unlocked, and max duty cycle that the solenoid sees is 97%. Low side driver.
However the duty cycle must be ramped up in a "soft start" fashion. I tried just grounding the control wire (effectively 100% DC I guess?) for grins and it made a bang and locked up VERY hard. Ive datalogged the TCM and depending on throttle position it generally spreads the ramp up from 0% to 97% over 1.0-1.4 seconds.
So basically Id like to make a circuit that, when you flip a toggle, it takes over control of the solenoid and manually ramps it up to 97% DC over the period of 1.0 second.
Ive done a lot of research and found many different methods of making a small PWM driver circuit, but Im just not sure which one is the simplest, and which one would do exactly what I want...
this one seems simple but it has no ramp-up function...could I add a capacitor in there to give it ramp-up? Also, it shows a dc motor there, im not sure if I would need a different FET thats specifically for controlling a transmission solenoid?
http://www.dprg.org/tutorials/2005-11a/index.html
here is another one I found, but it looks way more complicated and I feel like what I want could be accomplished with a similar circuit..
http://www.elecfree.com/electronic/wp-content/uploads/2007/07/ee2382390-1.gif
and finally, I found this FDMS2380 IC that seems to be perfect...its designed for automotive apps, specifically for controlling transmission solenoids!! But im not sure how I would wire it up. The fact that its surface mount is also kind of a PITA. And im not sure how I would get it to output 100hz PWM and do a specific ramp-up. Would I add a separate 555 astable circuit? Not sure how I would set that up either. In looking at the data sheet for this, im not sure why there are two control inputs on each channel, a and b?? Do both of them have to go high and then it will actuate the solenoid?? And why are there 4 separate outputs on each channel?
http://www.fairchildsemi.com/ds/FD/FDMS2380.pdf
thanks again for any help with this project..
ben
ben
