It would be helpful to know the planned voltage and the stalled voltage of the motor.I have NOS of the BP275, with an oc voltage of about 21.0
In looking thru my box of electrolytics, it seems I may have use caps in series, with balancing resistors.
I do have many unmatched 220 to 450v caps, and that is also an option.
I'm a little rusty: if I place two 75v 2000uf caps in series, then I increase the voltage handling, and decrease the
total capacitance, yes or no? So, in the above example = 150v & 1000uf?
If we had that we could choose some adjustment points so you don't have to redo things at the end.
My vote would be for multiple caps in parallel as when it is putting along the current they need to supply will be large, so more is probably better.
But yes, your thinking is correct.
