I'm building a flash circuit for an external flash for a DSLR camera. I found a component by Linear Technology called a photoflash capacitor charger IC with integrated IGBT driver. It's an IC that reduces the number of external components needed for charging the capacitor of the flash and it has a driver for an IGBT that is used to quench the discharge of the capacitor so you can get shorter flash durations which allows you to control the light output of the flash, have "red eye effect", and save energy in the cap so it doesn't empty completely everytime.
A longer drive pulse to the IGBT means a longer flash duration and thus higher light output and more of the capacitor's energy is used.
What I want is to be able to trigger the flash with my remote flash trigger that sends a very short single pulse. I can't control the pulse width of the remote trigger so i can't just link it to the IGBT driver. I want to set up the circuit to receive the pulse from the remote trigger that then triggers a pulse that is ADJUSTABLE to the driver.
