Pwm advise
jmh474
Joined Jun 26, 2014
46
Im building a cnc router and hoping someone can offer me a solution to my problem, iv got a Chinese spindle that come with an adjustable power supply controlled via a potentiometer. But the controller im using is pwm speed control. (leafboy akz250)
Is there a way to convert the pwm signal to control the speed of the supply
jpanhalt
Joined Jan 18, 2008
11,088
There is a possibility that the adjustable supply is actually putting out PWM. Have you checked?
In any event, it appears to be DC, but that also needs to be confirmed as well as the maximum voltage. If it is DC, then a PWM supply of the same maximum voltage should work
