Push- Pull from open collectors
Wendy
Joined Mar 24, 2008
23,798
I like comparaitors, Both the LM303 and LM339 are cheap.fast and useful.but the open collectors they use can limit their usefulness.I believe I have come up with a circuit that increase their drive
The drive on these comparator is only 18ma max and I have made no effort to control shoot through but the out will now be rail to rail.
cmartinez
Joined Jan 17, 2007
8,762
Noobie question: Wouldn't a totem pole at the comparator's output work just as well?
Wendy
Joined Mar 24, 2008
23,798
Emitter follower have The B-E drop(in this case on both rails.IMO the drive is better. In many cases the emitter follower will work just fine.I begrudge the1.2V You loose with it.
38,507
Just add a CD4050 CMOS buffer to get a CMOS push pull output.
You can parallel the 6 inputs and outputs to get more drive capability.
Wendy
Joined Mar 24, 2008
23,798
I have another protoboard project in the back of my head and an working toward minimum parts count.I can't build it but I can draw it.
