Ideally, we are looking at a few meters from underground tank
D Thread Starter DJ_AA Joined Aug 6, 2021 502 Aug 10, 2025 #41 Ideally, we are looking at a few meters from underground tank
D Thread Starter DJ_AA Joined Aug 6, 2021 502 Aug 19, 2025 #42 I emailed the manufacturer, and they confirmed that the datasheet contains an error — 35W appears to be accurate. With this type of pump, I am experiencing some failures, which I believe are due to restrictions on the output flow. Is that normally the case?
MaxHeadRoom Joined Jul 18, 2013 30,873 Aug 19, 2025 #43 See post #15, any restriction on the output usually results in lower current on the typical radial vane pump.
MaxHeadRoom Joined Jul 18, 2013 30,873 Aug 19, 2025 #45 DJ_AA said: But can it damage the pump? Click to expand... Not usually, only where flow is also used for motor cooling etc.
D Thread Starter DJ_AA Joined Aug 6, 2021 502 Aug 19, 2025 #46 Previously, i have experienced impellers and shafts snapping.
hrs Joined Jun 13, 2014 539 Aug 19, 2025 #47 Apart from the heat issue it can damage the pump if cavitation and/or surge occurs. What is restricting the output and what flow rate do you actually get?
D drjohsmith Joined Dec 13, 2021 1,662 Aug 19, 2025 #48 DJ_AA said: Previously, i have experienced impellers and shafts snapping. Click to expand... sounds like you need a better pump
