Pump Power Consumption: Why Am I Only Seeing 36W Instead of 60W?
DJ_AA
Joined Aug 6, 2021
502
This may be a trivial question, but I’m wondering if anyone can shed some light on pumps like the one attached.
I connected it to a bench-top power supply at 12V, and the current consumption is 3A — so a total of 36W — whereas the datasheet mentions 60W.
How accurate are these pump datasheets typically, or is there something I’m missing regarding the 60W rating?
I also noticed that both the 12V and 24V versions are listed as 60W.
joeyd999
Joined Jun 6, 2011
6,459
Actual pump power is going to be dependent upon the load on the pump, which is variable.
I assume a 60W rating means worst case under greatest specified load and worst ambient conditions.
The data sheet you attached doesn't appear to have any electrical specifications, nor is it related to a pump.
DJ_AA
Joined Aug 6, 2021
502
What would affect the load of the pump? As if you restrict the output water flow, the current drops, and if you leave it to the max as per the output terminal, it's about 35W
joeyd999
Joined Jun 6, 2011
6,459
I am not a pump expert, and you haven't shared the datasheet.
I assume they are telling you your power supply must be capable of 60W under all normal operating conditions, and through time (wear is also an issue), even though under most circumstances the pump will consume less-than-stated power.
joeyd999
Joined Jun 6, 2011
6,459
Further, as the manufacturer ships hundreds -- or thousands -- of pumps, it is unrealistic to assume each and every pump is going to consume 35 watts exactly at the end of the line.
There is some headroom in that number to account for pump-to-pump variations, plus a safety factor.
28,365
Some pumps go into a stall mode and the required motor torque drops, Other types of pumps work harder and harder so the motor draws more current. And some data sheets list the current for the largest motor available, instead of the motor you have.
28,365
No, but the motor power is a function of the amount of work the pump is doing. I have watched a hydraulic tech adjust the relief valve of a hydraulic power unit tighter and tighter until the clamp on ammeter read the motor's rated full load current.
28,365
OK, certainly a bunch of information and opinions. One thing I have not seen was the test condition: Was the pump actually moving water when the current measurement was read?? No-load and full load currents will certainly be different.
DJ_AA
Joined Aug 6, 2021
502
Yes, I placed it in a bucket and continuously filled the bucket with water, while a pump drained the water out.
GetDeviceInfo
Joined Jun 7, 2009
2,284
Power requirements to pump water are analogous to electrical power, such that pressure x flow rate, roughly equate to power. The head (pressure differential) of your bucket experiment, is relatively small, requiring less power then what the max ratings of the pump might be, resulting in lower current draws.
28,365
Certainly doing more work will require more power. Also, partly blocking the discharge will increase the current. About half power at a no-load condition is within reason.
MaxHeadRoom
Joined Jul 18, 2013
30,817
If it is a typical centrifugal radial discharge pump. any restriction on the inlet or outlet or a very low level of lift, results in a very low current.
The same applies to a typical vacuum cleaner motor for eg, where blocking the exit, the increase in RPM due to reduced load, can really be heard.
Pump technology such as rotary screw/hydraulic versions are the opposite , increase in load or blocking the oulet will result in a great increase in load.
ly
DJ_AA
Joined Aug 6, 2021
502
Yes, when the inlet or outlet is restricted, the current drops, so if I had to push the water to 10M, would the current increase? so how does the pump know when to increase the power to the motor?
MaxHeadRoom
Joined Jul 18, 2013
30,817
As per the previous post by @hrs if the oulet distance is increased by 10metres the current will drop.
The highest current is with zero distance at the outlet.
GetDeviceInfo
Joined Jun 7, 2009
2,284
If you don't have a head, your power requirements are lower. If you have a head, but no flow, your power requirements are lower. Max power will be at the rated flow over the max head. The efficiency of the pump will skew that somewhat.
So if I was pushing water to maybe 10 meters verticle upwards, would that require more current?
Not if you exceed the pumps capacity and flow falls off.
You want to calculate your whp, flow against a head, then choose a pump that can deliver, then drive it with a motor of rated horsepower. If your pump head can only develop 35 watts of work, a bigger motor won't change that.
GetDeviceInfo
Joined Jun 7, 2009
2,284
And all that excess power went straight to heat. Not good for hydraulic systems.
