Pulsed DC RLC circuit resonance-Revisited
DVESH
Joined Jan 1, 2016
1
Indeed. And you can excite (R)LC circuits to "ring" at any harmonic of the pulse base frequency. (if the duty cycle is 50%, you can only get odd harmonics, but if it is anything else, you can also get even harmonics. And if it's a very very short pulse, you can get ALL harmonics.
Eric
Hey Eric, may you please give some references about this concept?
I'm looking for the math involved in this, both for series and parallel RLC where a pulsed DC is issued. Thank you.
@KL7AJ
KL7AJ
Joined Nov 4, 2008
2,229
A perfect square wave (one with infinitely steep vertical slopes on the rise and fall) will generate an infinite number of odd harmonics of the repetition rate (fundamental frequency). The harmonics are ONLY generated during the rise and fall....the upper and lower (steady state) horizontal portions are DC which have no harmonic components.
