I am trying to find a solution for measuring fast pulse and later analysing the data:
Pulse lenght is about 500ns and I need to measure each pulse individually as they will happen irregularly.
The acquisition is simple holding the peak value for 3-4us and then resetting the capacitor by mosfet.
The problem is holding and detecting peak value.
The pulses are low voltage 0-1,8V.
I have tested some solutions and they weren't precise:
The typical peak detector with diodes does not give the exact value for various pulses (linearity was very poor)
My last hope is either OPA615, but it's quite expansive and I'd like to replace it with something (equivalent)... or "comparator" peak detector circuit. I've actually found only one such application (quite old) by Maxim: https://www.edn.com/design/analog/4347624/High-speed-peak-detector-uses-ECL-comparator
I've tried it in the simulator with other parts but it does not work. (What a surprise...)
What is best?
What is best?
