Pulse distortion in LED modulation
Kris@UA
Joined Apr 29, 2017
18
I am modulating an OOK signal (0.2 Vpeak to peak, 6 MHz) over LED (Please see fig.1). The signal after modulation is detected by a trans-impedance amplifier. In contrast to the input OOK signal, the output signal's low level amplitude is not flat(fig.2) in other words, the zero pulse duration is reduced. Can any one help me understand why this happens?
Papabravo
Joined Feb 24, 2006
22,116
Sure. The LED cannot respond to a 6 MHz. signal. It looks like the rise time of the LED response is faster than the fall time. This may be due to the persistence of the illumination in the transmitting LED after the driving current is removed. This type of response is typical of most optical circuits.
