Pulse discriminator using op amp TL084N
dudenukem
Joined Feb 12, 2018
22
Hallo,
I am trying to implement a simple pulse discriminator for pulses with 10 Hz frequency using TL084N using the scheme from the attachment.
I have put that circuit on my breadboard using an input generator and an oscilloscope to watch out the response.idscr_question.png
However, the output level of the op amp isalways 5 V.
Any hints where I am going wrong?
Thank you!
AlbertHall
Joined Jun 4, 2014
12,636
The amplitude of the pulses is 250mV but what two voltages are the pulses between?
They could be from 0V to 250mV and then your circuit would work fine or they could be between 1V and 1.25V and then your circuit will always output 5V.
dudenukem
Joined Feb 12, 2018
22
I'm attaching the oscillograms: Ch1 is the input and Ch2 the output of the circuit, I've reduced the Vref to 160 mVSCRN0062.PNG
LesJones
Joined Jan 8, 2017
4,509
Are you sure that you have not mixed up the inverting and non inverting inputs. With your circuit I would expect the output to be at almost zero volts. I would not expect to see anything on the output unless the input goes above the reference voltage. Are you sure R2 will adjust low enough to get down to a reference voltage of 230 mV ? I would have thought a 3.3 K potentiometer would have been a better choice. I can't find any information on the data sheet The minimum supply voltage, None of the graphs show it with less than + and -5 volts supply. Try connecting the - supply pin connected to - 5 volts rather than 0 volts.
Les.
AlbertHall
Joined Jun 4, 2014
12,636
So I have to interpret the display of an oscilloscope that I have no knowledge of?
What does 'ofs -202mV' mean?
What happens if you disconnect the input pulses?
dudenukem
Joined Feb 12, 2018
22
"ofs" is the offset - I just pulled it up and down so that the oscillograms will not overlap. Here is the oscillogram at 0 offset:
Following your question of disconnecting the Generator, I see that the open circuit voltage (that is without generator) at the non-inverting input is about 360 mV. Where it comes from? Via the resistance R4?
38,577
The TLO84 will not operate well with a single 5V supply. It needs a minimum of ±5V (see data sheet snip below):
You need a single supply or rail-rail type op amp.
An inexpensive example is an LM324/LM358 although its maximum output is about 3.5V with a 5V supply.
You could also use a comparator such as the LM339/LM393.
dudenukem
Joined Feb 12, 2018
22
Les.
I can change th epotentiometer later on. I was thinking about the supply voltage too, but looking at the data sheet I saw that it can also operate with a single supply.
dudenukem
Joined Feb 12, 2018
22
Yes. There is something wrong ... I guess it is better to rebuild it and start all over again. I'm out of my wits for such a simple circuit ... I'll come back with news asap.
38,577
That's if the input is biased at about 1/2 the supply voltage and the supply voltage is ≥10V.
Look at the common-mode voltage range (below).
It does not go to the minus voltage.
The input voltage range is 3V above the negative supply voltage (±15V) or 3V above ground if the negative supply is ground.
You can keep fussing with that op amp but it's not likely to do what you want.
sghioto
Joined Dec 31, 2017
8,673
Crutschow is correct you will never get that circuit to work correctly without a duaI supply, verified myself using a TL082. MCP602 is a better choice.
SG
dudenukem
Joined Feb 12, 2018
22
Indeed the power supply is a must for this op amp. I tried with a dual power supply but still I have troubles running the above circuit.
Therefore I replaced the op amp with a comparator 8049 LM311N and adapted a bit the circuit as follows:
Using a single 5 V power supply I have the required result:
I guess this will give me a better behavior at higher frequencies than the op amp.
Thank you all for your help!
DickCappels
Joined Aug 21, 2008
10,661
This can be done with a single supply by raising the power supply voltage to about 12V or higher and putting the bias back to 50% of the supply.
Audioguru
Joined Dec 20, 2007
11,248
The TL08x, TL07x and a few other old opamps have a problem where the output suddenly goes as high as possible if an input voltage gets within a few volts from the negative supply voltage. It is shown here:
