Hello all,
I've finally took the courage to attempt to fix my HD9240 airfryer. Same issue as others reported, didn't power up anymore. I've opened it and the two resistors were cracked. Replaced them with 33 ohm 5W 5% that I've sourced from conrad, turned on for 2 secs and the resistors heat up to the point of started to glow.
I've replaced the Viper16L and now the unit doesn't blow resistors anymore but the panel doesn't power on either.
Does anyone knows what else I can test (very limited knowledge in electronics) to check if something else is broken that I can replace to avoid spending 190 eur in a new airfryer XL ?
I appreciate all the knowledge already present in this thread.
Cheers.
Cheers.
