Identifying blown components-3D Finder
srecenvid
Joined May 10, 2018
31
i am trying to fix my cnc 3D Finder, sadly i cant find any schematics for pcb so i need some help. I have 2 components visibly damaged/blown up. I made some close pictures with microscope but i am not able to see any smd code on what i assume it is resistor. I was able to read code on SOT-23-8 (my assumption) 8-pin smd. It is G9C, but no result were fond so far. I have no idea how to find right parts unless someone of you can help me :)
AlbertHall
Joined Jun 4, 2014
12,653
I found quite a few components coded G9C but none of them have 8 pins.
The 9C looks clear enough but are you sure the the first character is G?
srecenvid
Joined May 10, 2018
31
So i think i found right part. According to datasheet and DG449DS have marking on the chip G9x. Also i checked pcb pins and it corresponds to one in datasheet. Now real question is what resistor do i need? When i measure blown resistor (or maybe its not) it is 15Ohm. Datasheet for DG449DS dont have any useful information for resistor.
https://www.vishay.com/docs/73897/dg449.pdf
Any help is welcome :)
