proximity sensor 2 meters
wertamaki
Joined Apr 14, 2020
Hi, can anyone help me with ideas on building devices that produce an audible signal when come close to each other, say 2 meters or less. Both devices continue signalling until they are two or more meters apart. Think about a microphone moved close to a speaker - you hear an unpleasant screeching sound until you move them apart.
Device requirements:
Portable: yes
Unit price: cheaper is better, max 5$ each.
Size: smaller is better, max cigarette-box-size.
Sensitivity: audible signal if distance between units is between 0 and around two meters. No signal if distance is more than that.
Power: battery operated
PS. I read some articles on the topic, including Bluetooth IPS - used in museums e.g. But that would probably cost $$$. For a non-tech like me, microphone-speaker setup seems appealing, but two-meter-range might be hard to achieve in a cheap and small device...
Any ideas?
Wertamaki
AlbertHall
Joined Jun 4, 2014
12,654
How accurate does the 2 metres need to be?
Will the devices be oriented to face each other or is the system required to work wherever they are pointed (e.g. if one was in your pocket)?
wertamaki
Joined Apr 14, 2020
Thank you for your reply.
No need to face or point. It should be in your pocket and signal when someone with same device approaches you in any direction. It should work on it's own, without pressing a button, pointing, etc.
Precision: +/-50 cm.
wertamaki
Joined Apr 14, 2020
AlbertHall
Joined Jun 4, 2014
12,654
Light and ultra sonic are ruled out, so that really only leaves radio and I don't know of any system which would come close to your requirements.
