protect PCB board from moisture
ep.hobbyiest
Joined Aug 26, 2014
201
I am using one PCB board in the machine which comes in contact with moisture. I want to protect that board from moisture and getting damage because of it.
What are all the preventive options available?
35,326
First preventative measure - keep it away from moisture.
Second preventative measure - cover it with conformal coating, twice.
Thirdly - enclose it with waterproof enclosure.
If condensation occurs, then skip #3 and use a heated cabinet with drainage holes and ventilation.
