I've been wanting to make a battery powered and Bluetooth low energy controlled recording sign, so I could ultimately send it to a friend who has a podcast. Since I've been recording lots of videos, it's at the top of mind. I've put these sub-systems into different products and projects in the past so this time the "new" aspect will be coming from the programming, the actual assembly of the box and attaching vinyl in a sane manor.
Here's my first log entry from June 15:
The first step of any project is to get the scope of how you’re imagining it will look down on paper. Rough dimensions are good but first figuring out what materials and processes will be required helps set the stage for later down the road.
For this project I figured I would need a way to cut some frosted acrylic to size. Approximately 11.8 x 3.93 inches (30 x 10cm). The idea being that I could mount any type of additional design to the customer facing side. Whether that be a negative cutout or positive cutout.
The “cutout” would be created by a vinyl cutter which could them be transferred to the frosted acrylic.
On the Inside
On the inside, some consideration has to be made for the LEDs. LEDs have an optimum viewing angle but also get dimmer from when you directly look at them to when you look at them from the side. The sweet spot looks like 30° to 30° that most of the LEDs maintain their intensity above 90%.
After doing some high school geometry, of which I have not done in a long time, I was able to determine that the optimal distance from the back of the acrylic is about 1.8 inches with a 4inch high view port. (note that in the scan of my notes, I actually did the cosine instead of tangent calculation)
The calculations lead to requiring at least 12 LEDs for a 30cm x 10cm configuration. That makes for a total of 36 LEDs to control. That may be 3 LED controllers right there.
A quick current feasibility study leads to the following:
1 color == 12 LEDs
1 LED == 15mA current
12 * 15mA = 180mA
So (a super quick and dirty calculation) a 4AH battery may last 22 hours of use.
6AH = 33hr
12AH = 66hr
24AH = 132hr
On the outside
The box itself would be made of MDF, or similar, with a 45° cut on all ends so that the guts of the MDF is hidden from view. The box could them be painted.
I found the design of others signs particularly interesting. One company used a textured paint. It reminds me of a LineX truck be liner consistency. It’s nice because it hides the joints where the 45° angles meet with the wood.
On the Inside
1 color == 12 LEDs
12 * 15mA = 180mA
6AH = 33hr
12AH = 66hr
24AH = 132hr
On the outside
