While programming a PIC chip with the PICkit3, should the components attached to the PIC pins be pulsed on and off erratically?
For example, I have an LED and a 20x4 LCD display connected to the PIC. During programming, the LED flashes erratically and similarly, the LCD cursor moves around erratically.
The target (PIC circuit) and the LCD are both powered with 5V while programming. There is a 4.7K resistor tieing MCLR to VDD, and all other pins from the PICkit3 are connected directly to the PIC.
The programming itself is successful and the circuit behaves correctly when running the PIC.
Is this behavior normal while programming using ICSP?
A second question is, while debugging, should the status LED on the PICkit3 turn red? Even with a simple LED flashing program, the status LED stays red until the chip is reset.
Kind regards,
Chris
Kind regards,
Chris
