Endless help, increadiblehi,
This PDF is an introduction to jFET's.
E
E
Hi, eric. In case of the schematic you posted, isn't 4mA current offset provided by Q3 dependent on +Vcc? That would be quite problematic.hi arrian,
It provides the 4mA offset current.
I will post an option.
E
Tweak the values to suit your App.![]()
You're right, I thought changing Vcc would mess up more. Anyway, zener diode works pretty well. Final design in the attachment.hi arrain,
It is dependent upon the stability of the 12V supply, that is why the sim 12V is specified as 12.0v.
If the stability is a problem you could use say zener or the TL431 option shown in post #22.
E
EDIT:
This is with a 6v2 zener, add a 100n across the zener.
BTW: have you tested the performance of the 4mA source using +/-1V on the 12V supply.?
The change is not detectable.
What about R2?hi arrian,
Is the section of the power supply you plan to install a 6.8V 10Watt Zener.? If so, I don't see any current limit resistor.??
E
I expect around 1A current draw from the LM7805, which means around 0.3A draw from +Vcc and zener diode at 17V.hi,
What will be the current loading on the +v and -V
Look at this Sim, using 1K as dummy loads.
What do you expect the current to be thru the 10Watt zener.?
E
Unless you are using switch mode regulators, the current from the 17V supply will be 1A as well. Actually, even higher if you are extracting current from the 12V point. Linear regulators input current is the same as output current, ignoring the small control current. So heatsinking will be needed. A switch mode supply will save the heat and the current from the 17V supply will drop significantly.I expect around 1A current draw from the LM7805, which means around 0.3A draw from +Vcc and zener diode at 17V.
I see, switching regulator will be a better choice. What chips do you recommend? Will eg. AOZ1282CI or AP5100WG-7 be suitable for this application? Or maybe fixed-5V one like this: IFX91041EJV50?hi arrian,
I agree with 'dendad' point, use a SMPS, your present circuit is very inefficient.
E
Yes, I mentioned it in my question. I guess It will fithi arrian,
Have you considered a ready built SMPS module, from eBay or Amazon.
The IFX d/s is attached.
E
It seems like IFX91041EJV50 is not quite popular. The datasheet briefly describes the typical application for fixed output, but some things are not clear for me. What is max EN enable voltage, can it be connected directly to +Vcc (17V)? What value should D7 have? Is it supposed to short over-voltage spikes, being eg. 10V schottkey diode? I know It is probably somehow written in the d/s but I want to clarify my concerns, since there are no egzamples on the web.hi arrian,
E
| Thread starter | Similar threads | Forum | Replies | Date |
| B | PIC16F18857 causes 220Ω 4–20mA shunt to measure ~61Ω after being soldered onto the board | Microcontrollers | 5 | |
Design for a current source for transducers with 0/4-20mA output. | Analog & Mixed-Signal Design | 15 |
