Unlikely, since that would be proprietary information.Hello,
Is there any site where I can see the physical parameters of each MOSFET process?
Thank you
If you worked for a company that made them or used a foundry.Is there any site where I can see the physical parameters of each MOSFET process?
As @danadak has already pointed out -- you can't.Actually the design is for a project and indeed it's my first design. All the exercises I 've seen so far ,had these parameters given. I am wondering how you start a real design without knowing these parameters. For example, a 180 nm process may be better than a 90nm process for a specific application. How could I conclude in which process is the best for my design if I don't do the design first?
The copper process | IC Design | 2 | ||
L | 13.56 MHz Power Amplifier Reverse Engineering Process | PCB Layout , EDA & Simulations | 3 | |
How can I process video from camera module via FPGA to Android Device (2) | Homework Help | 0 | ||
M | MOSFET turn on process | Power Electronics | 3 | |
D | How to process a funky signal. | General Electronics Chat | 73 |
