Problems with constructing a 24bit counter
MikeHutao
Joined Aug 2, 2024
11
Hello im trying to build a counter to count up until 10MHz using Logisim. Does this software have any limitations ? because the count doesnt work. i think i have connected it well based on the datasheet.
here i provide the corresponding file
Papabravo
Joined Feb 24, 2006
22,113
What signal is on the bottom trace that goes from 0 to -1 and back to 0? That is the key.
ETA: If you write the successive counts in binary, it should make it obvious where the problem is located.
51455 = 0b 1100 1000 1111 1111
55296 = 0b 1101 1000 0000 0000
When the least significant counters rolled over you incremented the wrong counter and one of the counters remain unchanged. That is the one you should have incremented.
