Problems with back to back MOSFET dimmer for 24VAC
38,947
Thanks for your reply! I meant that my load has to be placed on the other side, connecting to m2 and I was thinking that the return path through m2 would then pass a small current through the load constantly even when the mosfets are off?
Why does your load have to be connected to the other side? :confused:
It makes no difference on which side the load is connected as far as the load is concerned.
Lars Englund
Joined Dec 31, 2016
17
The IRLZ44N ON resistance, as stated in the data sheet, is not specified below a Vgs of 4V.
No, but the MOSFET bias will be incorrect.
Notice that the bridge rectifiers clamp the negative AC voltage to ground, which fouls up the MOSFET bias.
As shown below this means the M2 will conduct through its body diode for the negative half of the sinewave even when the gate voltage is zero.
Hmm, thanks alot @crutschow, you've been extremely helpful!
I really need to learn LT spice.. tried simulating your first circuit but it complained about missing 1n4002, guess I need to find some component libraries somewhere first..
Lars Englund
Joined Dec 31, 2016
17
38,947
Yes, I've added some libraries for some common devices that aren't in the standard LTspice library, but you can use other similar diodes in the library to do the simulation without a significant effect on the results.
