I.m trying to measure line voltage (220V) using the Avago chip HCPL-7520 but I found some problems.
Based in https://forums.adafruit.com/viewtopic.php?f=8&t=112761 , I connected the chip in the same way, but values I got in from the 7520 were not as expected. The problem I have is, I got always the same voltage independently of what voltage I have in the line from 120V - 230V.
I tried using the 7520 with a transformer 220V/9V AC and the result were the same. But when I used DC instead of AC , 7520 perform according the datasheet.
So I convert AC to DC using this configuration(attached) to measure the 220V line but it doesn't work at all.
Could somebody help me pointing me out what is wrong?
Thanks in advance for your help!!
