Yes NSD is shut down pin but I normally don't connect shut down pin with others. I am not sure it's correct.There's a shut down pin on the ic shown on the datasheet. Is it connected correctly? I can't see reference to it on your circuit diagram
YesS
So you suggest I should use dummy RF loads instead of the electronic load.
It's not connected correctly in your schematic. Check the IC datasheet.I used Mbr1645 schottky diodes for boot strap.
Where are you measuring the current?The problem is that even though I increase the dc supply voltage to MOSFETs, the current is not increased at all (0.0mA)
No. D5 cathode should connect to VB, not to VS as you show in your schematic.I think I connected correctly.
The current from dc power supply.Where are you measuring the current?
Thank you so much. I didn't know that. I will correct and test again.No. D5 cathode should connect to VB, not to VS as you show in your schematic.
