Problems after hot air soldering component in PCB - BNO055
btondin
Joined Apr 27, 2013
7
I ordered some BNO055 to hand solder to my boards in 2016, but this year I decided to remove them to put in a another board with mikroBUS standard. I don't know how the Moisture Level Sensivity (MSL) of this chip, but since it's System on Package I assume that it's no 1.
After soldering in the new board i realize that the RAW value of the acceleration have a huge offset (in horizontal the values should be X= ~0, Y = ~0 and Z = ~9.8, but now the Z is less than 9.8 and i have some offsets from 1 to 4 in X and Y axis).
Then I got one cjmcu-bno055 (chinese breakout board for bno055) and everithing was fine with the values using "out of the box". So i decided to remove the IC and solder to my board, and i got the same issue with the values.
I put my board in breadboard just to have the same condition of the CJMCU-BN055 board.
Any suggestion about this? I did a permanent damage to the IC since I resoldered by hand (didn't follow the JEDEC reflow profile)?
Now i'm afraid that i did the same with some Hillcrest's BNO085 :(
dendad
Joined Feb 20, 2016
4,641
It is quite possible you have cooked the ICs. It is very easy to do.
If you can get some new ones, I think it would be worth replacing them and see what happens then.
btondin
Joined Apr 27, 2013
7
Yeah. I'll do that. But all the logic and stuff works perfectly, seems that the "accelerometer inside" the SIP got damaged
dendad
Joined Feb 20, 2016
4,641
I have damaged ICs like that myself. It is easy to overheat them.
The worst overheating was when I decided to fix a iMac video card in surface mount reflow oven. The oven had not been used for a long time and it was now faulty, as was indicated by the clouds of smoke coming out of it :(
My son wondered if the board would still work, so like an idiot, I plugged it into the iMac and promptly blew up the motherboard.
Not a good day!
