Problem with voltage doubler
idrbur
Joined Jan 11, 2018
11
I'm trying to make a voltage multiplier but it didn't worked so i tried to make a voltage doubler but when i made a halfwave doubler and provided it with 24 volt ac it produced 12 volt dc and when i made a full wave voltage doubler it gave me 8V dc when provided with 24V ac.
Can anyone tell me whats wrong can be going on.
I'm using1n4007 diodes and 1nf 2kv capacitors.
Thanks in advance
shteii01
Joined Feb 19, 2010
4,644
Thanks in advance
Schematic, where?
sghioto
Joined Dec 31, 2017
1,038
Thanks in advance
Image from Electronic-Tutorials.ws
Your half wave doubler should look like this. Assuming you have it wired correctly the problem is most likely the 1nf 2kv capacitors. Those are way too small in value for proper filtering. Start with some 100uf-50volt caps and check again.
SG
AlbertHall
Joined Jun 4, 2014
9,873
Thanks in advance
Is the input frequency 50Hz, 60Hz, or something faster than that?
How much current are trying to take from the output?
idrbur
Joined Jan 11, 2018
11
The circuit is same as given by sghioto and the power supply is of 50hz, and i don't think cap value is problem cause i have seen many people using cap of this much value
AlbertHall
Joined Jun 4, 2014
9,873
The capacitors are way too small.
With 1nF and no load you will get 70V. Even a 1MΩ load will reduce the output to less than 12V.
