Help me sir -diode voltage doubler problem
MrAl
Joined Jun 17, 2014
13,805
Your original solution where you have the final value of Vout as 2.5 volts is not correct as you seem to have realized. The solution where you later found the final value of Vout to be 3 volts is correct.
