Problem with simulation in proteus???
Generation
Joined Apr 4, 2020
11
I built the circuit for simulating the all-pass filter by using optocouplers. But I don't know why its frequency response differs so much from the same but with the resistors instead of the optocouplers.
JohnInTX
Joined Jun 26, 2012
4,787
Welcome to AAC!
A quick scan of your .zip file shows no problems but you should know that most members, including me, will NOT open a .zip file due to security concerns. Please post files in their native format.
Good luck!
Generation
Joined Apr 4, 2020
11
Welcome to AAC!
Good luck!
I can't post it, because file's format is unallowed here. So I can post images:
Img.1 - two circuits(the higher one is the circuit we want to work as an all-pass filter, the bottom one is with resistors instead of optocouplers)
Img2.jpgImg.2 - the frequency response of the circuit with the resistors and the response which we like
Img3.jpgImg.3 - the frequency response of the circuit with optocouplers instead of the resistors. In theory it shouldlook exactly like the Img.2
Img4.jpgImg.4 - the characteristics of the operational amplifiers I use. I thought it might be the reason for this difference, I know it's not right but still.
If I must post something else, please tell me. I'll do it.
bertus
Joined Apr 5, 2008
23,025
The PC817 optocoupler will not create a linear resistor.
Better use an optocoupler with a fet as output, like the H11F1.
Bertus
Generation
Joined Apr 4, 2020
11
Bertus
What if I don't have H11F1 in Proteus, can I interchange it with some another linear optocoupler? Or can I download a package for Proteus with it?
