Problem with LTspice: Time stop too small
Firenze02
Joined Sep 1, 2018
47
I'm trying to create a variable resistor dependign from the value of current.
Please find attached the .asc file.
It doesn't work, when I run the simulation the following messages is presented:
Analysis: Time step too small; initial timepoint: trouble with node "n002".
Do you know how to fix this problem?
Thank you.
Firenze02
Joined Sep 1, 2018
47
hi F02,
Look at this link for 'extra LTS features, they may suggest alternatives.
E
http://ltwiki.org/index.php?title=Undocumented_LTspice#Behavioral_Resistors
Dear ericgibbs, thank you for sharing me this information.
Being "gshunt" the optional conductance I set that to a very lowe value G=1/R (high Resistance).
Please find attached the last version of the .asc file.
As you can see, I set an "if" statement in the R value, following the sintax:
R=if(condition,valueiftrue,valueiffalse)
How can I do if I have three interval?
I<1mA a=a1=10.2576
1mA ≤ I < 10 A a=a2=14.6851
I > 10A a=a3=0.5415
Do you know the correct sintax?
Really thank you.
eetech00
Joined Jun 8, 2013
4,724
Try using “Limit”.
In the example below:
MIN=the minimum value for R
MAX=the maximum value for R
equation=your “if” statement
R=Limit(MIN,MAX,equation)
eT
Bordodynov
Joined May 20, 2015
3,431
I am sorry. .opt gshunt=1n.
Perhaps you specified an unreal function and therefore there is no solution. When I asked the inverse function, the solution was found.
