Problem with DIY high voltage regulated Power Supply
e00rica
Joined Jan 11, 2021
5
I am writing this post in the hope that someone can help me to solve this problems. I found this project on the internet and since I need this kind of power supply, I decided to build a similar one.
I basically have two problems with the circuit: One is that when I have regulated the voltage down to a few millivolts and let it stay there for a few minutes and try to raise the voltage again, the transistor (Q7) smokes. Problem number two is that R8 resistor gets too hot when Q1 is leading. I resolve this by placing a 1 Kohm effect resistor between Q1-Source and earth but I'm not sure it's the right thing to do.
Thank you!
Here is the youtube-link for the project I found on internet:
by Smith Kerona
AnalogKid
Joined Aug 1, 2013
12,295
What is the maximum output current you want at 300 V, 150 V, 5 V, and 0.1 V?
Your basic problem is excessive power dissipation in your components. There are three equations for this, all variations of the same theme:
P = E x I
P - E^2 / R (Watt's Law)
P = I^2 x R (Joule's Law)
If you pick an arbitrary output condition, such as 10 V at 1 A, you can work backwards through the components and see the power dissipated in each.
Linear power supplies are inefficient by definition, and that means they produce a lot of heat. If you have 10 V at 1 A at the output, then 300 W ((310 V-10) V x 1A) is being dissipated somewhere. That's a lot. You'll need fans.
AND - what is the purpose of R12. At 1 A output current, the voltage drop (Ohm's Law) is 100 V, reducing the maximum output voltage to 200 V, and the power dissipation is 100 W.
ak
tindel
Joined Sep 16, 2012
939
This is not a trivial power supply to develop. I'll suggest three edits.
1)
Your Q2 transistor is smoking because your bandwidth is too high. i=C*dv/dt. If you assign it to 200V and it gets to 200V too quickly, you have very large currents charging your output caps and taking you out of your safe operating area of the transistor. You need to add some slew rate control. I'd suggest readding the opamp your removed from the original circuit and filtering its input signal to have a time constant of ~1s (or more) to limit the speed at which the output voltage ramps up or down after an adjustment has been made.
2)
Adding the Rsense and Q2 in this image will provide a rough current limit - better than R12. More info can be found here: Current limiting - Wikipedia. This will also help with #1.
3)
The video describes that mosfet as having a large input capacitance - and he's right! I'd pre-bias the gate so that it's always charged up. Basically, add a resistor on the trim pot so the output can't ever be less than some value, perhaps 1V. This has the added benefit of not needing a very good (ie fast slew rate) opamp since you limit the performance to only the small-signal.
AN104 - Load Transient Response Testing for Voltage Regulators (analog.com) This app note describes what I'm talking about and provides some additional circuitry to achieve high-bandwidth regulation with a mosfet. The app note describes regulating current, so a different application, but the ideas are the same.
And a few comments:
4)
I noticed you decided to us a 12V diode in place of the reference. This is okay as long as you understand that it's not very accurate and that it will drift with time and temperature. This is not what you really want with a lab power supply, however. They do make 10V references if you do want to lose the second op-amp (not recommended - see note 1).
5)
I'd be careful with C18 and C19. C18 will slow the speed of your opamp - which you don't want. C19 will do two things as currently implemented. It adds a differentiator to the opamp (which often leads to instability) and it will add a filter to your D1 reference - which is okay, but the bandwidth of the filter will change as the trimpot is adjusted.
6) There really should be a comparator comparing the commanded voltage to the actual voltage and tripping off (latching) if there's a difference for too long a time (a couple of second - must be longer than #1) so it doesn't kill someone. This is a safety critical item.
7) Do you have an oscilloscope to test if you have any ringing in the output? A multimeter in AC mode might suffice too, but oscilloscope will probably give more information if you do have ringing.
e00rica
Joined Jan 11, 2021
5
Hi and thank you very much!
For a few weeks ago, I bought a transformer in hope that in the future I can built a bench variable power supply for use in equipment development/ troubleshooting on vacuum tube circuits. In the secondary winding I have the 6.3 and 12.6VAC that I need for filaments, a 150Vac that I want to use for grid bias (1-2mA) and finally the one we talk about in the topic, the 644Vac which will be around 800 variable and regulated and which I want to use as plate supply (100mA).
Anyway, with the help of a variac, I want to start with 0-300V instead of 0-800V and that's where I'm right now!
analogKid: Regarding your tips about power dissipation. I thought about it and therefore use high power resistors R8=5W and R4=50W and heat sink on BJTs and MOSFET. The components are not very hot when they are in operation, but as I said before, the transistor breaks as soon as I increase the voltage up from zero.
I think that I will try, as tindel recommended, go back to the original project and use instead for the Zener diode the two comparators found in an AD823. This if I can find one, not easy to find cheap components these days. Do you have anything else that you can recommend?
Thanks,
Richar
e00rica
Joined Jan 11, 2021
5
Now I have made some progress in my 800VDC power supply. Have tested on my breadboard (without load)
and it seems to work. Still have not implemented the tripping off (latching) circuit that you suggest Tindel.
have tried different connections without success. Is any body that can help me here?
thank you,
AnalogKid
Joined Aug 1, 2013
12,295
In the voltage regulator, I don't see any reason for R18, R19, R2, and R3. The AD823 is a rail-to-rail opamp; its output can swing low enough to turn off Q3.
R2 and R3 form a 2:1 attenuator. Why do you think this is necessary?
What is the purpose of C7? The output impedance of U3a is low enough to completely swamp it, so I don't think it does anything.
C3 and C23 are unconnected.
In the main schematic, you should add high-value resistors in parallel with C1, C2, C14, C15, C16. This will assure better voltage distribution across the strings.
ak
e00rica
Joined Jan 11, 2021
5
Ok, I will test this changes! R2 and R3 (Regulator) is there for compensation do to the MOSFET large input capacitance which can cause oscillations. Any sugetions about how to solve Tindel issue nummer six:
thank you!
AnalogKid
Joined Aug 1, 2013
12,295
Yes, but the equivalent value of the combined resistors is in series with the gate capacitance, forming a lowpass filter and phase shift network. This could make stability worse, not better.
I don't know what your experience base is, so this might not be necessary. But . . .
The reason most people put a resistor in series with a power MOSFET gate is because they were taught to - but not always taught why. The gate capacitance, when combined with PC board trace and/or wiring inductance can form an L-C tank circuit that rings (damped oscillations) at a very high frequency when stimulated by a driving signal with a fast edge. Fast transitions improve efficiency in switching power supplies, but you can have a 100 kHz switcher that fails FCC certification at 250 MHz because of this ringing. The gate resistor damps this ringing; the larger the resistor, the better the damping - but also the larger the phase delay between the output of the gate driver and the circuit action at the drain.
Another reason for the resistance is to limit the peak current into an uncharged gate capacitance. For large MOSFETs this can be in the 10 A range. This can damage a simple driver circuit grown outof discrete components, but most opamps these days have internal current limiting to protect themselves. Note that when an opamp output stage shifts to constant-current protection, this is another source of time/phase delay.
ak
