Hi Guys!
I have problem with a Stepper Motor 24 DC drived by Motor Driver (A3950 Allegro).
At the outputs of Motor Driver i found the same value of OUT A, OUT B (24 Vdc) and a signal on NFAULT pin indicate a problem with the chip.
When I connect the motor, OUT A and OUT B (that were at 24 Vdc) fall at 0Vdc and the motor, of course, does't start.
I know that the correct values are OUT A = 24 Vdc and OUT B = 0 Vdc to rotate the shaft clockwise, otherwise OUT A = 0 Vdc an OUT B= 24 Vdc for the anticlockwise.
I have controlled all values of all pins and the values of capacitances and resistor used, but I can't understand because it doesn't work.
Thank you in advance.
