Problem with a circuit to measure of displacement
Mousivandhossein
Joined Dec 8, 2020
34
I designed and built a circuit to measure displacement.
I made a coil and connected a wein oscillator to the coil, which changes the voltage at both ends of the coil by moving an iron rod inside it, then by ideal rectifier, the voltage of the coil turned to DC voltage.
unfortunately, now the output of the circuit changes about 1% when the rod not changing and the rise of temperature can change the output about 4-5% for the rod to remain fixed.
Can you please help me to improve my circuit against the variation of the output? or if you know a better circuit, please suggest it.
Thanks and Best Regards,
AlbertHall
Joined Jun 4, 2014
12,640
The oscillator should be running at about 3.4kHz.
The iron core will increase the inductance and so increase the voltage across the inductor, but the iron core will be quite lossy at that frequency and this effect will tend to reduce the voltage.
Maybe, try a ferrite rod core for the coil?
What is the inductance of L2?
Mousivandhossein
Joined Dec 8, 2020
34
Thanks for your reply.
Yes, the frequency of the oscillator is about 3.4 kHz.
I can not find a ferrite rod to replace with iron rod.
The losses do not matter to me, only I want to have a stable output for a fixed rod iron, the output variation is my most important issue.
L2 is the coil, The coil has 2000 turns and its length is 270 mm and its diameter 9 mm.
The distribution of the windings is uniform.
Marley
Joined Apr 4, 2016
519
So your displacement measuring device depends on the change of inductance with the position of the ferrite rod?
A good concept. But:
Not sure why you chose the oscillator frequency to be 3.4KHz. Also why the capacitor on the oscillator output is 1uF.
The impedance of the 1uF capacitor is about 48 ohms. This is in series with the output impedance of the oscillator op-amp which will also be quite low. Possibly less than 10ohms. I don't know much about the inductor but the impedance could be quite high at 3.4kHz. What is its impedance at the limits of travel?
The "potential divider" formed by the capacitor and the op-amp output on one side and the inductor on the other is dominated by the low impedance of the capacitance verses the high impedance of the inductor.
Also, the output will be affected by any drift in the oscillator frequency.
I would change to a much higher oscillator frequency. Tens of kHz at least. Make it stable. Either a crystal oscillator or derived from a crystal with a divider. This could also have the advantage that the inductor has less turns.
Have a resistor in series with the oscillator output that has approximately the same resistance as the impedance of the inductor at half travel. Then the "potential divider" of impedances will show the maximum change with displacement.
And the rod inside the coil must be ferrite. Similar to the type in old AM transistor radios. As the frequency goes up, you need to consider the effect of stray capacitance affecting the output. Might need to screen the coil with metal - but without forming a shorted turn. Wind the coil on an aluminum tube with a slot all the way down so eddy currents cannot flow.
Mousivandhossein
Joined Dec 8, 2020
34
The losses do matter as they will affect the voltage output of your circuit.
Do you have a brass, copper, or aluminium rod that will fit the coil?
How much displacement are you trying to measure?
How long is the coil?
Thank you for your reply.
I did not try rods made of brass and aluminum. I think ferromagnetic materials are more effective in increasing the amount of inductance. But I tested the 316 stainless steel rod and it did not work
I think brass, copper and aluminum have the same result as SS 316.
Mousivandhossein
Joined Dec 8, 2020
34
Thank you very much for your good tips.
now I change the oscillator frequency to 20 kHz and I try to calculate the inductance of the inductor and then I will put a resistor series with the output of op-amp and check the output stability.
I will tell the results here.
Marley
Joined Apr 4, 2016
519
If you use a solid metal rod inside the coil the eddy currents induced in the metal will destroy the inductance. A ferrite rod has magnetic properties but does not conduct. You can buy ferrite rods. Or, find an old AM radio and get one from that.
Mousivandhossein
Joined Dec 8, 2020
34
I want to convert the ratio between voltage and rod position to a curve and find the exact position of the rod by fitting a function to the curve based on the output voltage.
To calculate I want to use a microcontroller.
Mousivandhossein
Joined Dec 8, 2020
34
In your opinion, the eddy current losses can change the output with the fixed iron rod?
When the iron rod is not in the coil, I see the output has a little variation, it is my important issue.
No changes have been made to the circuit yet.
Mousivandhossein
Joined Dec 8, 2020
34
hi,
What change in inductance to expect over the range of rod insertion.?
E
I have not yet measured the range of inductance changes.
Last night I tested the circuit, the DC output changed from 1.265 V for the rod was out of the coil and 3.924V for the rod quite inside of the coil.
when the rod was out of the coil the output voltage changes from 1.259 V to 1.272 V.
when the rod was quite inside of the coil the output voltage changes from 3.915V to 3.930 V.
Mousivandhossein
Joined Dec 8, 2020
34
Better results to be had with "Linear Variable Differential Transformer" configuration - LVDT for short.
Google it.
First I decided to instruct the device according to LVDT, but the range of work of it was limited and a wider range of coils was needed to get an acceptable result.
However, I have not to experience with LVDT.
Sensacell
Joined Jun 19, 2012
3,787
What is the performance you need?
Linear Range...
Response time...
Accuracy...
Linearity...
Physical size...
Power consumption...
35,024
That's a rather ingenious way to measure displacement.
Why not use a linear resistance coil or track or even a 10-turn pot with a rack and pinion or a flex band. A voltage divider circuit is a lot simpler, more linear, accurate and stable.
You could even use the same coil as variable linear resistor by scraping off the insulation and putting a wiper on it.
Mousivandhossein
Joined Dec 8, 2020
34
Linear Range...
Response time...
Accuracy...
Linearity...
Physical size...
My request is based on priority:
1- Accuracy (+-0.5 mm accuracy and stable output when the rod fixed)
2- linearity (however I can linearize the output with a microcontroller)
3- Physical size (I have about 300 mm space for measuring 250 mm)
4- power consumption (max 2 W)
5- response time (settling time about 0.25 sec is good)
