i'm new here and so thankful i've found this forum.
i've desperately tried to figure out how to make my homework, so i've searched the net and ended here eventualy.
i've tried to figure most of the problems by reading older posts, but this one is different.
The problem:
There's a need to design an electric circuit which turns on a LED in exit F dependens on the income of A.B.C with the following terms:
1) The LED will turn on when A appears and B appears after.
2) The LED won't turn on when B appears and A appears after.
3) in the 2 cases above, the circuit gets locked until C appears. (C=Stop=zeroing).
Implement the circuit using logic gates.
(I'm sorry if it sounds a little funny, i've just translated it from another language).
Thanks a lot!!!!!
The problem:
Thanks a lot!!!!!
