Print floating point values using STM8S103FP Mini Dev Board
Prasad_123
Joined Jun 19, 2024
2
I am doing a Current, Voltage Measuring project using INA219 Current Sensor and using STM8S103F3P Mini Development Board. And monitoring the data in Serial Monitor. But I am not able to read/write Floating Values. For Eg: If the multimeter measures 21.28 mA then I am only getting 21 when I use int or long int. And if I use float then random symbols like "????" occur in the serial monitor.
What can I do to print floating values or how can I print values more precisely?
33,192
You don't give very much information, such as what language you are programming in. But you might try printing your value to a string and sending that string across your serial link.
Prasad_123
Joined Jun 19, 2024
2
I am using Embedded C to Program STM via ST-Link V2.
here is small cutout from my program
C-like:
int readCurrent(void) {
    uint8_t reg[2] = {0};
    uint16_t raw = 0;
    I2C_GenerateSTART(ENABLE);
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT));
    I2C_Send7bitAddress(INA219_ADDRESS << 1, I2C_DIRECTION_TX);
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
    I2C_SendData(0x04); // Current register
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED));
    I2C_Send7bitAddress(INA219_ADDRESS << 1, I2C_DIRECTION_RX);
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_RECEIVED));
    reg[0] = I2C_ReceiveData();
    reg[1] = I2C_ReceiveData();
    I2C_GenerateSTOP(ENABLE);
    raw = (reg[0] << 8) | reg[1];
    // Return current in microamperes (µA)
    return raw; // Assuming calibration constant
void sendCurrentReadingToUART(void) {
    int current_uA = readCurrent();
    char buffer[50];
    sprintf(buffer, "Current: %d µA\n", current_uA);
    UART1_SendString(buffer);
    UART1_SendString("\n");
35,180
Your raw data is an 16-bit integer value in steps of 10μV.
For example 32000 decimal is 320.00 mV or 0.32000 V.
You can do all your math in floating-point format if the MCU has enough memory space to do this. I am not a big fan of FP arithmetic on a small MCU.
My suggestion would be to convert the integer into a string array and then insert the decimal point where it is required, i.e. depending on if you want to show V, mV, μV and A, mA, or μA.
