Laser print 10mm round labels?
AlbertHall
Joined Jun 4, 2014
12,654
I want to print resistor values on 10mm round labels. I have hand written them but they are not clearly legible (120k on a 10mm label gets a bit crowded).
I have libre office but it doesn't seem to have an option for 10mm labels.
Any suggestions?
AlbertHall
Joined Jun 4, 2014
12,654
It certainly does.
Now I just need to find out how to create a database with a list of the values and print from that.
panic mode
Joined Oct 10, 2011
5,307
one can simply use spreadsheet (calc) to create one set of values such as 1, 1,2, 1,5 .... 9.1 then clone it and apply multiplier and unit. if you want the list in a database, LibreOffice does have Base for that.
28,454
With a color printer it would be simple to print the color code, probably straight across. THAT will be much easier to read without magnification.
AlbertHall
Joined Jun 4, 2014
12,654
Now that is a neat idea!
But I only do monochrome and that doesn't justify a new printer. I think the laser printed ones should be legible but it has just occurred to me that it would make the handwritten ones easier to use three numbers like capacitors do - 124 for 120k.
