Hello everyone, i'm trying to build a pan/tilt turret with a laser mounted on it that is controlled by a bno055 mounted on eyeglasses. I have the sensor working but the problem is i want to mount it on the left temple changing the default orientation. When i try reading data this way, pan also affects tilt, as in they change together when i only change yaw. I have tried p0-p7 axis remap and none worked. Any suggestions ?
ESP32 Code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
/* This driver reads raw data from the BNO055
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground
History
2015/MAR/03 - First release (KTOWN)
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055(-1, 0x29, &Wire);
void setup(void)
Serial.begin(115200);
while (!Serial) delay(10); // wait for serial port to open!
Serial.println("Orientation Sensor Raw Data Test"); Serial.println("");
/* Initialise the sensor */
if(!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
delay(1000);
bno.setAxisRemap(Adafruit_BNO055::REMAP_CONFIG_P4);
bno.setAxisSign(Adafruit_BNO055::REMAP_SIGN_P6);
bno.setExtCrystalUse(true);
Serial.println("Calibration status values: 0=uncalibrated, 3=fully calibrated");
void loop(void)
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
/* Display the floating point data */
Serial.print("X: ");
Serial.print(euler.x());
Serial.print(" Y: ");
Serial.print(euler.y());
Serial.print(" Z: ");
Serial.print(euler.z());
Serial.print(" pan: ");
Serial.print(" tilt: ");
Serial.print("\t\t");
