Pretty good weekend effort
joeyd999
Joined Jun 6, 2011
6,456
If the theoretical is a straight line, it may be tough to justify the significance of any additional terms. They might help fit existing data but not really have much predictive value.
The coefficients for the 6th order polynomial were generated based upon the measured discharge characteristics of a set of Energizer alkaline batteries. I had no expectation that the Duracells would track exactly -- simply because of what I am sure are differences in the manufacturing process (even the chemistry might be subtly different).
I am not surprised by the overall result. The only surprise was those few hours where the terminal voltage did not change at all. It's possible that the the electrolyte in the Duracells is more mobile than that in the Energizers, at least at that point in the discharge curve.
I am interested enough to repeat the experiment to see if it holds for another set of Duracells. But I cannot do that till I again have some free time -- perhaps in the next few weeks.
This is not an important problem. More of an intellectual curiosity.
Tesla23
Joined May 10, 2009
560
How are you accounting for temperature - this has an enormous effect on battery performance. In your discharge test, did you hold the temperature constant? It's possible you are fitting higher order terms to your room temperature profile.
From Energizer website for an alkaline : http://data.energizer.com/pdfs/temperat.pdf
wayneh
Joined Sep 9, 2010
18,162
Make sure you control for temperature as much as you can. Changing ambient temperature could cause some anomalies.
I suspect that a method called ARIMA might give a better result. It’s basically a moving average but with a random walk. It’s a common way to model stock prices, for instance. I think for a battery you would always predict a linear decay from wherever you are at the moment.
joeyd999
Joined Jun 6, 2011
6,456
How are you accounting for temperature?
I'm way ahead of you guys:
It doesn't compensate for temperature, but it doesn't have to.
All I want is a 0% battery life at ~1.8V (regardless of temp) and a very rough estimate of remaining battery life elsewhere. Again, this is an academic exercise. I was curious how close I could get to an accurate estimate without accounting for temperature.
Yebbut...constant power does complex things to the basic discharge curve. The load increases as the battery ability to support loads decreases.
Exactly, for my solar battery monitor I dynamically compute discharge and load run-time parameters using a sizable number of real-time and historically derived data points. Chemical batteries are like living creatures under load.
cmartinez
Joined Jan 17, 2007
8,855
very interesting ... I don't know much about batteries actually (in case you haven't noticed) ... so, what you're saying is that the battery's internal resistance changes as it's discharged?
joeyd999
Joined Jun 6, 2011
6,456
I'm saying the terminal voltage is a function of temperature, state of charge, and load.
Batteries are extremely non-linear devices. I think my first shot was a pretty good estimate -- well within expectations. It's just the strange response over a few hours that surprised -- and interests -- me.
cmartinez
Joined Jan 17, 2007
8,855
And I'm interested too ... especially about that strange plateau at between 30-35 hrs ... So this is what I'm beginning to grasp: batteries change their behavior depending on (among other things) rate of discharge, and that would mean that their performance changes from device to device. So that means that the curve you've calculated applies to your device only, is that it?
joeyd999
Joined Jun 6, 2011
6,456
Yes, but I'm trying to generalize it a bit. The power required by my device does change depending on certain things.
joeyd999
Joined Jun 6, 2011
6,456
I simplified my encoder code a few weeks ago, and I forgot to post an update. It works highly reliably now. Here is the interrupt routine:
Code:
;** ENCINT -- Encoder Interrupt routine **
encint    swapf    portb,w        ;capture new encoder value (bits 4:5 -> 0:1)
    andlw    b'00000011'    ;mask encoder inputs
    bcf    intcon,rbif    ;clear interrupt
    rlncf    _enclst,f    ;shift old values
    rlncf    _enclst,f
    iorwf    _enclst,w    ;merge in new
    andlw    b'1111'        ;modulo 16
    movwf    _enclst        ;save as new last
    call    _cjump
    bra    eina        ;no action
    bra    eidec        ;decrement
    bra    eiinc        ;increment
    bra     eina        ;no action
    bra     eina        ;no action
    bra     eina        ;no action
    bra     eina        ;no action
    bra     eina        ;no action
    bra    eina        ;no action
    bra     eina        ;no action
eidec    decf    _enccnt,f    ;decrement minor encoder counts
    bra    eiupd        ;and process hysteresis
eiinc    incf    _enccnt,f    ;increment minor encoder counts
;process hysteretic state machine
eiupd    cjump    _enccnt
    bra    eist0
    bra    eina
    bra    eist2
    bra    eina
    bra    eina        ;midpoint of current count
    bra    eina
    bra    eist6
    bra    eina
eist0    bcf    _encbup        ;reset back to mid-position
    bcf    _encbdn
    movlf    _enccnt,4
    bra    eina
eist2    bbs    _encbdn,eina    ;decrement one major count
    bsf    _encbdn
    bcf    _encbup
    bra    eidn
eist6    bbs    _encbup,eina    ;Increment one major count
    bsf    _encbup
    bcf    _encbdn
    bra    eiup
;increment major count and set up flag
eiup    incf    _encinc,f
    bsf    _encup
    bra    eiex
;decrement major count and set down flag
eidn    decf    _encinc,f
    bsf    _encdn
eiex    bsf    _encrdy        ;indicate new encoder data ready
eina    goto    intdone        ;and get out
And this is the "user space" polling code:
Code:
;** POLLENC -- Poll Encoder **
pollenc    movlw    b'00001111'    ;preclear static flags
    andwf    encflag,f
    bbs    psenc,peeact    ;encoder active and initialized?
    retbc    pcenc        ;inactive and off, do nothing
    bra    encinit        ;otherwise, initialize
peeact    bbc    pcenc,encoff    ;turn off encoder if necessary
    retbc    _encrdy
;capture encoder increments since last check into temp0
    bcf    intcon,rbie    ;disable further interrupts
    movff    _encinc,temp0    ;capture increment
    movff    encflag,temp1    ;capture volatile flags
    clrw
    movff    wreg,_encinc    ;and increments for next pass
    clrf    encflag        ;clear volatile flags
    bsf    intcon,rbie     ;reinable int
;add signed 8 bit increments into cntnew
    movfw    temp0        ;get increment/decrement
    addwf    enccnt,f    ;update new counts
;set static flags
    swapf    temp1,w        ;duplicate low nibble to high
    andlw    b'11110000'
    iorwf    encflag        ;set static flags
    return            ;and get out
The flag definitions are:
Code:
#define    _encrdy    encflag,0        ;1=Optical Encoder data ready
#define _encup     encflag,1        ;1=encoder up
#define _encdn    encflag,2        ;1=encoder down
;#define     encflag,3        ;
#define    encrdy    encflag,4        ;1=Optical Encoder data ready
#define encup     encflag,5        ;1=encoder up
#define encdn    encflag,6        ;1=encoder down
;#define     encflag,7        ;
#define _encbup    encflag1,0        ;hysteretic bits
#define _encbdn    encflag1,1
joeyd999
Joined Jun 6, 2011
6,456
And, dammit!, I am still waiting for the last part to arrive for my new transducer, the whole reason why I have embarked on this project.
Tracking shows that the part has visited all over the world the past few weeks: Philippines, China, Japan, Hawaii, and California so far. Just not Florida.
It should arrive in the next day or so -- tanned, rested, and ready.
cmartinez
Joined Jan 17, 2007
8,855
and you ordered only one unit? o_O
joeyd999
Joined Jun 6, 2011
6,456
No, silly. But I am only assembling one transducer for starters, therefore, I only need one part.
If the one does not perform as expected (assuming all else is correct), there is no point in building more: the project (a proof-of-principle of the new transducer) will have been a failure.
cmartinez
Joined Jan 17, 2007
8,855
How long ago did you order that component?
And yes, I've been there, alright. I know the feeling of laying one's hope on a single component ... good luck!
joeyd999
Joined Jun 6, 2011
6,456
The part in question is a stock part that I use in my daily course of business. I was unaware until two weeks ago that I did not have one in stock -- until I received all the other parts I required for the build.
The part I am waiting for is not the questionable part of the build. The finished transducer (as a whole) is.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Have you ever looked into the P18F2331/4431 series?
They have a Motion feedback module in them, aimed at quadrature encoders etc.
There are 100p/rev quad encoders on ebay for ~$2.00, includes the metallic slotted disk and slot detector.
Apart from the odd 12F series, I generally just use the P18F series now.
Max.
joeyd999
Joined Jun 6, 2011
6,456
This might be attractive if I were developing a motion control project.
But I am just using the encoder for menu scrolling and quick and easy adjustments. The PIC was selected to support what I require to run the transducer.
joeyd999
Joined Jun 6, 2011
6,456
The parts just arrived. Yay!
Building transducer as we speak. It'll be a few days till I have final results.
But at least I have some real work to do now.
