Pressure to Flow calculation
pandian
Joined Sep 27, 2009
33
Hi Gurus
I have Nitrogen gas line.
Set pressure at 3bar (pressure gauge at N2 inlet)
Outlet (1/4" teflon tube) splits and connected to 2 flow meters with max scale at 40LPM.
1. How do i calculate the max flow for each flow meter (assuming the meter can read infinite value).
2. How much the presure will drop if both flow meter reading 40LPM?
Thanks in advance
studiot
Joined Nov 9, 2007
4,998
The flow rate does not depend upon the Y junction or the meters.
A gas feed line should be able to maintain the inlet pressure, regardless of the end conditions, until the gas runs out.
The flow rate depends upon the pressure difference between your 3bar (I assume this is gauge pressure?) and the pressure at the discharge point, so what is that please?
18,130
Flow and pressure drop also depend on the length of the tubing, the equivalent length of any bends, corners, imperfections and so on, and on the inner surface's friction factor. Depending on what flow rates we're talking about, you may need to estimate the Reynold's number.
33,023
Sure it depends on these things, just as the voltage of a power supply depends on the load. In theory it shouldn't, but in reality it does because the gas supply has an effective impedance (the valve only opens so far and the gas passage is only so big) and the line and meters have an impedance.
studiot
Joined Nov 9, 2007
4,998
We have nowhere near enough information to properly answer the OP.
All sorts of scenariaos are possible.
Which is why I asked for more details.
However I gained the impression that the OP had a setup that operated comfortably within system capabilities and sound engineering practice.
In which case my statement is correct.
I did wonder what the split was for, it could even come back together at the load if this was part of a diving NITROX air supply.
33,023
I completely agree that we don't have enough information. 1/4" tubing is going to have some pretty significant impedance, so if they run it very long at all it is going to drop a fair amount of pressure.
EDIT: typos
Kermit2
Joined Feb 5, 2010
4,159
I can tell you that 50 feet of 1/4" air hose will have about 1 psi of pressure drop with 2 CFM of flow and about 100 psi of pressure drop with 20 CFM of flow. I'm not doing the conversion math on this one.
