Electric Pressure Washer add Flow Switch and Timer Relay
tsax6010
Joined Mar 28, 2020
I am looking to invest in an electric pressure washer from Northern Tool, 5HP 230v 30a electric motor
https://www.northerntool.com/shop/tools/product_200347872_200347872
Unlike cheap electric pressure washers that turn off when the trigger is released, this one keeps running much like a gas unit, relying on a temperature bypass relief valve to dump water when it gets too hot from recirculating through the pump which takes about 2 min from all accounts.
I would like to add a flow switch on the high pressure outlet of the pump like this model from General Pumps
https://www.generalpumponline.com/p...reedless-brass-flow-switch-10-gpm-4000-psi/t/
To minimize wear and tear on the motor and pump from quick cycling (releasing the trigger momentarily for safety, change position, etc for a few seconds) I would like to add an adjustable relay timer to keep the motor running for say 15 seconds after the trigger is released to give some margin of convenience to allow continued use without shutting down and promptly restarting the motor.
Any thoughts on such a timer? All of the 230v ones I see out there max out at 10amp - does the rating of the relay and flow switch need to match that of the motor? Is there a better flow switch for the application I should be looking at - maybe a flow switch with an integrated timer function?? Also any thoughts on wiring the solution up to the existing on/off switch and 5 HP Leeson motor?
SonOfaSwitch
Joined Nov 28, 2022
Quite literally exactly what I got on the internet to solve not but 5 minutes ago. With the ease of WiFi/smart devices I thought that would be the easy solution, however it always tripps the built in GFCI on the pump. Did you ever solve this by chance?
Reloadron
Joined Jan 15, 2015
7,926
This thread is over two years old so likely a new thread would be in order defining the GFCI tripping problem. Next, is the added switching added up or down stream of the pump GFCI? This would likely go better with even a rough schematic of the modifications done.
Ron
