Powering Analog Switch Above Recommended Voltage Ratings
SkiBum327
Joined Apr 29, 2019
Hi Guys,
I'm new here. I'm looking to incorporate some analog switches into my circuit design (https://www.nxp.com/docs/en/data-sheet/NX3L1G66.pdf).
In the datasheet, it is stated that the supply VCC as well as the logic signal for the switch (open / close) should not exceed 4.6V, but that the signal passing through the switch can go up to 4.6 + 0.5 = 5.1 V.
My main bus is at 5V, and the logic signals I am connecting are also at 5V.
I am wondering, is it okay to use 5V rather than the specified 4.6V?
If this is not recommended, is it reasonable to down regulate from 5 to 4.6, since in my (limited) experience, linear regulators require a decent dropout voltage.
dl324
Joined Mar 30, 2015
18,463
Welcome to AAC!
It's inadvisable to operate any device at it's absolute maximums.
The device is spec'ed for operation from 1.4-4.3V.
38,797
That switch is designed for 3.3V systems.
Buy one that's rated for over 5V maximum or 5V nominal, perhaps like one below:
