Hello!
I have an idea for a project that sounds fun, but I’m not sure how to proceed (or if it's even possible). I have an Aaxa pico projector that I would like to power off of an Anker 20100 portable USB charger on backpacking trips. I know the anker charger is capable of outputting 4.8A total (2.4A from each port) and that the aaxa projector has input requirements of 5V at 3A. Is it possible to build a circuit that will plug into both ports on the Anker charger, negotiate those power requirements, and then output them to the projector?
I did try building a circuit from a similar project I found on the internet, but the circuit doesn't power up. This other project took batteries and stepped the voltage and current down to USB levels (link: http://www.instructables.com/id/Universal-Portable-USB-Charger/). I've included a picture of the original circuit, my modified circuit drawing, and the physical circuit I built (please forgive the horrendous soldering job; It's been a while and I need a new soldering iron!).
Originally I tried splicing the power cable that came with the projector to a USB plug to see what would happen. It does provide power, but far below the requirements, which isn't good for the bulb or the projector. I then tried to splice it into a USB Y split (similar to what external hard drives use to draw more power), but it didn't affect the output much. I suspect it's the negotiation piece I'm struggling with, since the Anker powercore has a bunch of safety features and this projector was never designed to run off USB power.
So what do you guys think? Doable, or should I walk away from this one? I took Physics 2 in college (E & M) and have dabbled in circuits before, but nothing like this. If someone can help me with the design bit, I'm excited to build it and share my results.
Thank you,
Tom
Materials:
http://www.aaxatech.com/products/p3_pico_projector.htm
https://www.amazon.com/gp/product/B00X5RV14Y/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Thank you,
Tom
Materials:
