- Joined Jan 23, 2018
- 28,240
Mod:deleted quote
CERTAINLY that is a valid question. Perhaps now going after an EE degree??
I am NOT a certified mechanic, but I AM familiar with auto electrical wiring and the parts about what the wiring can support is fairly accurate. The wire sizes are only almost adequate for the fuses, and often the assorted voltage drops, both on te feed side and on the "ground" side are not to be ignored. And my two inexpensive inverters, 400W and 800W, each draw a bit over ten amps powering a 100 watt incandescent bulb. So they are not so wonderfully efficient. And there is no way that the inverter input terminals are adequate for what the rated output operation must draw, at least on my inverters.
