Powering a 12 vdc microphone.
Tryin2learn
Joined Nov 11, 2016
102
Hiya can someone help?. I have been trying to add a microphone to my CCTV system the problem is when I use one of those 240 vac to 12 vdc adapter's I get sound from the microphone but a hell of a lot of interference I know it is originating from the adapter but don't know of a alterative way of powering the microphone . Any help would be greatly appreciated thanks Keith .
Tryin2learn
Joined Nov 11, 2016
102
LesJones
Joined Jan 8, 2017
4,511
Is it not possible to pick up 12 volts from the CCTV system to power the microphone. It will only require a few mA. I would also suggest putting say a 1K resistor in series with the positive and an electrolytic capacitor of between 10 an 100 uF between 0 volts and the microphone side of the 1 K resistor. This may even work with one of your switch mode power supplies. It may also be worth putting a 100nf mylar or ceramic capacitor in parallel with the larger capacitor as it will filter out high frequencies better than an electrolytic capacitor.
Les.
Tryin2learn
Joined Nov 11, 2016
102
Les.
Thanks for your help . I am going to try the linear adapter idea first as it is simpler ( save's me getting the ladder out again ) Keith
