I am looking at the Injoinic IP5328 to be used in my powerbank project. The datasheet has a reference schematic and I have doubts if it is complete. I am attaching the schematic below, while there is a terminal for the VBAT+, the connection for the negative terminal of the battery is nowhere mentioned.
I want to use a different battery protector, How do I design the circuit in that case? Should I connect both the output from both MOSFETs (charging and discharging) to the same terminal(VBAT+)?
If the image is not clear, Here is the datasheet but it is available only in Chinese and I have been using Google Translate to read it.
