No big deal, and you're welcomeOT & BTW (this references a project from last fall). I never did thank you Sarge for the idea of using a LM317 in current limit mode on the motorcycle's LEDs. Brilliant solution to the fluctuating voltage. Wired it onto a mini-board with a barrier strip for the line connections. Works perfect!
The LM317 as a current regulator isn't ideal, due to the relatively large voltage drop (3v) when used in this manner. However, it's one of the most simple ways to achieve decent regulation, without wiring a bunch of components together.
