That resistor just tricks the supply so it will turn on. Its 560 ohm. My problem is figuring out what the black square thing is between the possitive and negative and what could it be doing? I have a hand full of these supplies already that work by adding the resistor on the left at 12.4 volts.Just add a like resistor to the second supply you want to modify. That should do it. If you are unsure of the resistor value just lift one leg of the resistor on the modified supply and measure it.
Ron
