Power supply development
Azhaganandhan
Joined Jan 18, 2019
I have a bit of knowledge in electronics. need to provide +12 -12 GND power supply to a photosensor, but don't have the particular device to power it. I'm using smps right now, by connecting v+ and GND output pins don't give any output, please let me know is there any easy way to handle this scenario
28,595
You may be able to have it function on + and - six volts if you use a voltage divider across the 12 volt supply. But that may not work.
If the supply has a transformer and diodes, then you could add another set of diodes to get a negative 12 volts supply. But the supply is a switch-mode supply so that would not work. There are some voltage inverter circuits but they are sort of complex.
It might function if you tied the -12 terminal and the commn on the photosensor together. If it is a photosensor that you built and it uses an opamp, let us know, there are a number of options in that case.
