problem with variable voltage circuit development.
vinay sv
Joined Nov 16, 2020
11
Thanks for your support in this forum.
Currently, I am working on a project in which the operating voltage is 12v 1.5A to be given to the circuit. but, my input power supply varies from 12v to 24v of 2.5A. but I am not getting an idea that how to get constant voltage regulation of 12v of 1.5A to my circuit. and my circuit load will be always constant.
38,918
Even low dropout IC regulators typically require a volt or so minimum voltage across them so I don't know of any that will work if you need very near 12V out with 12V in.
What is the minimum voltage you circuit will operate at?
vinay sv
Joined Nov 16, 2020
11
thank you for your replay crutschow,
my minimum voltage requirement is 12v of 1.5A, but my internal circuits are at microcontroller level and some buzzers. so, it can also work on 11.5 to 12v for the basic working.
Papabravo
Joined Feb 24, 2006
22,115
It is possible to use a SEPIC converter, where the input can be less than , equal to, or greater than the output voltage. They do have disadvantages though.
Bordodynov
Joined May 20, 2015
3,432
THL 25-2412WI Vin=9V-36V, Vout=12V, $62.3 (Mouser Electronics)
25 Watt DC/DC converter, industrial, 4:1 input, encpasulated, 1″ x 1″ metal package
The THL 25WI series is the latest generation of dc-dc converter modules with highest power density. The product achieves 25 Watt output power and comes in a metal case with small dimensions of only 1.0”x 1.0”x 0.4”. All models have a wide 4:1 input voltage range and precisely regulated output voltages. High efficiency of up to 90% makes this product very reliable and applicable in temperature ranges of up to +80°C or up to +85°C with optional mounted heat sink. Typical applications are in mobile equipments, instrumentation, distributed power architectures in communication and industrial electronics and everywhere where space on the PCB is critical
vinay sv
Joined Nov 16, 2020
11
Can you tell us more about your power supply?
Is it adjustable from 12V to 24V or is it unregulated
Thank you sir for trying to help me out,
the input power supply varies from 12v to 24v based on the user choice which means there might be a chance of the user might choose to give 12v or 24v based on their type of gadget. because I am developing a slave gadget that depends on the master gadget power supply.
DickCappels
Joined Aug 21, 2008
10,661
You might find the circuit in this application note to be helpful. With the right parts selected it will hold its output at +12V regardless of where the input voltage wanders between 24V and 12V. It boost the voltage when the input is 12 volts and it buck the voltage down to +12 volts when the input goes about 12V.
With the use of more appropriate transistors it can be made to handle more current
As Papabravo mentioned there is also the SEPIC topology but I have little familiarity with that topology.
@Papabravo, I'm listening to Alice's Restaurant as I type. Thank you.
38,918
I mentioned a linear regulator but that would dissipate 18W with a 24V input and 1.5A output, so a switching regulator is the way to go.
It doesn't require a buck-boost converter, just a buck converter that can go to 100% duty-cycle (most don't).
The LTspice simulation of an example circuit is shown below.
Note that the output voltage (green trace) stays at 12V for an input voltage of 24V to 12V (yellow trace).
A search shows some other similar converters.
