Power supplies and Amperage!!
electronewb
Joined Apr 24, 2012
260
Let's say an electronic device is rated for a power supply at 12VDC @ 1A Would it be OK to use a power supply if the voltage is the same in that case 12VDC but at higher amperage?
#12
There is a certain level of n00bie that it fits just right, and you asked just the right question to be a likely fit.
Glad I could point ya' to it.
electronewb
Joined Apr 24, 2012
260
So basically the voltage has to be the same but the amperage will work as long as it's equals or above the device rating So in that case a 12VDC 100Amp supply would work?
mozikluv
Joined Jan 22, 2004
1,435
hi,
were's the logic of using a 100A PSU? of course it will work because the current that will be drawn will only be what the device requires.
mozikluv
35,146
Not quite. A 12VDC 100A supply is a car battery.
When you are prototyping and experimenting you do make mistakes sometimes.
Have you ever shorted out a car battery? The results are spectacular.
You need a power supply that has short circuit protection.
For simple electronics experimentation, a simple 9VDC @500mA adapter into a LM7805 voltage regulator is a better choice.
#12
The comments aren't too flattering to the writer of that paper!!!
and yet, there is a certain audience that it is perfect for...like you.
The result? I don't send "hopelesly pedantic" people to read it (as one of the criticizers signed himself).
MBVet05
Joined Jul 21, 2011
27
You should always use a power supply rated at or just above what is needed. If you need a 12v dc at 1A then a power supply rated at 1-30vdc at 3a is suffiecent.
