power sockets/ DC devices
MisterBill2
Joined Jan 23, 2018
28,332
yeah but the worst thing is its stated nowhere in manual. Maybe only option to contact manufacturer.
That is not mentioned because just like data sheets, very specific values are difficult to reproduce exactly. AND, it would confuse a lot of people who would not even understand.
thor21
Joined Sep 29, 2024
435
but is it okay to do it way i proposed?
use 16awg (in regards to Ampers there is huge capacity) and depends on the length and Voltage drop; i buy psu which will have Total Voltage = {Voltage of the endpoint device} + {calculated Voltage drop}
thor21
Joined Sep 29, 2024
435
so i found from the old laptops
1) 19.5V 6.7A
2) 20V 3.25A
any idea if i can use both of these in case the original one is 19V 3.43A?
using awg18 -> 1V drop (option 2)
using awg 16 -> 0.65V drop (option 1)
thanks!
MisterBill2
Joined Jan 23, 2018
28,332
@MisterBill2 i was not aware of that , ie a computer can sustain 1v drop. Its computer yes.
Consider that the actual computer system logic uses either 5volts, or more likely 3.3 volts, although if there is an LCD color screen there are other voltages also used. My small computers also have a 12 volt battery pack. So the 19 volts is regulated down by switcher power supplies.
MisterBill2
Joined Jan 23, 2018
28,332
OK, and keep in mind that none of that system runs on 19 volts. Computers might still use 12 volts to spin a hard drive, but probably not current ones. So that voltage goes straight into a switcher regulator.
thor21
Joined Sep 29, 2024
435
okay seems that main point regarding the V drop is missing in the whole thread hence whole approach here is pointless...
the voltage drop happens only during the load, possibility to increase PSU voltage wont fix anything it can damage endpoint devices.. especially usb ones.
Higher current ... bigger drop etc...
The only solution is to use 12/24 and dc-dc modules close to the endpoint devices 12/24 to 5v
or 3-5.5V to 5V dc-dc module, these modules are pretty costy...
https://www.pololu.com/product/2574?utm_source=chatgpt.com
seems the whole design that was on my mind is faulty.
MisterBill2
Joined Jan 23, 2018
28,332
The TS has just described to the rest of us exactly the reason why we do not have DC voltage distribution wide spread in most buildings. Having long wires for power delivery past the rectifiers and regulators and filters leaves an uncertain voltage drop in the wires. Certainly that drop is a problem that many folks choose to avoid.
thor21
Joined Sep 29, 2024
435
@MisterBill2
because i used 1mm2 core,
i changed to 6mm2 core and i cant measure with voltmeter drop... so apparently its not about drop but something else...
MisterBill2
Joined Jan 23, 2018
28,332
@MisterBill2
OK, not the resistance but still, it could be the inductive reactance causing a problem. Or even being a resonant length. ALSO, consider the added cost of the heavier wire. It might also be an inadequate connection someplace in the circuit.
My point is that certainly DC distribution has been possible for many years, but is very seldom used. Possibly for a valid reason? IF it were the better choice many folks would use it.
thor21
Joined Sep 29, 2024
435
Wire was 15 euro.
I dont know what is it. All 6 devices works fine... Only that one is problematic.
Yes i dont wanna have in living room 10 power sockets, and mess the space. And i dont wanna use any cabinet.
thor21
Joined Sep 29, 2024
435
to that problematic device voice-pe i will add as chatgpt suggested
Add a capacitor close to the Voice PE input:
  • 470 µF – 1000 µF electrolytic
  • + 100 nF ceramic in parallel
